Displaying chart on different screen for viewing
Currently in my front panel I have 3 charts displaying realtime data.  One of the charts is a gauge and I would like to move (drag) this chart to another screen that I have connected to my computer. This will be used as feedbak for subjects to view. I would like to keep the other two charts on my current monitor so the I can monitor performance on this screen.
1. Is there anyway to do this?
2. If so, how would I go about doing this.
The attached figure explains the question better.
Thank you in advance for you help!
(2,874 Views)
Hi Trodruiguez,
      This is pretty basic stuff, but there are a few details...
  1.       Create another VI - call it Meter.vi - with just a meter-control on the front panel.
  2.       Associate the meter-control with the connector-pane
  • right-click on connector-pane icon, choose "show connector"
  • click on connector, click on meter-control
     3.       Change meter.vi to "show front panel when called"
  • right-click on connector-pane icon, choose "VI Properties"
  • Category "Windows Appearance"\Customize
  • Select "Show Front Panel When Loaded"
  • OK, OK
     4.       Use positioning tool (plus-sign or arrow) to select the connector-pane, copy it to clipboard (Ctrl-c), paste it on your "Main" VI's diagram (Ctrl-V)
     5.       On the main diagram, wire the current meter's data-source to the connector of meter.vi
When you open/load the main VI, Meter.vi should pop-open, and when you run Main, the meter-control should update just it does on Main.Smiley Happy
 Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,845 Views)
