Displaying equations on the front panel
What is the best way to display (for lack of a better term) "pretty looking" equations on the front panel? I want to display equations that look like they would in LaTeX or Microsoft equation editor. Thanks.
Message 1 of 10
(6,902 Views)
Are the equations set or can the user edit them? I would generate the pictures beforehand and display them in a picture control.
Message 2 of 10
(6,888 Views)
The equations will be set. This seems like a good idea, but I have never used a picture control before.  Could you provide an example?
Message 3 of 10
(6,863 Views)
This link may guide you in a possible direction. You can use it to create a gif of the equation and then display it in a picture control.
Ben64
Message 5 of 10
(6,838 Views)
Also have a look at Darin's Math Node for some possible ideas. (not quite the same, but still....)
Message 6 of 10
(6,821 Views)
You mean something like this?
Like everyone else said make it a picture and just place it on your panel.
I think I made the formula using the Equation Editor that was part of MS Office.
=== Engineer Ambiguously ===
Message 7 of 10
(6,816 Views)
Unfortunatly there is no way to export the result of the Ms Equation Editor to another application.
Ben64
Message 8 of 10
(6,808 Views)
Ben64
Sure there is!  🙂
Also:  altenbach thanks for posting that link.  I hadn't run into it before and that is fantastic code.
Message 9 of 10
(6,797 Views)
@BowenM wrote:
Ben64
Sure there is!  🙂
I meant programmatically and without having to start an Office application
Ben64
Message 10 of 10
(6,775 Views)
