Displaying error message when waveform graph isn't receiving data.
I am sending data with UDP from one VI to another. How can I display an error message when my waveform graph isn't receiving any data (If I stop sending data to the waveform graph)?
Message 1 of 9
(2,860 Views)
Hi new number,
When there is no data for your graph then there is an error upstream.
Just react on that error to show the dialog!
Message 2 of 9
(2,855 Views)
Thanks for the reply. When I stop sending data there is still the data or number that was last sent. Is there a function that recognizes that the data is standing still?
Message 3 of 9
(2,851 Views)
So there actually is data but it's not "moving" or "updating".
Message 4 of 9
(2,840 Views)
Hi number,
Now it's time to show your code?
How is there "still data" when you stop sending data?
Yes, sure. But when handling errors/conditions upstream you don't need to detect "unchanged" data…
Generic recommendations:
When there is a problem in YOUR code then you should attach YOUR code.
Attach real code: we cannot debug/edit images in LabVIEW!
Message 5 of 9
(2,830 Views)
Translation for my VIs:
UDP_Sprejemanje=UDP_Receiving
UDP_Pošiljanje=UDP_Sending
So in UDP that is receiving I want to display an error message if I stop sending data from the other VI.
Message 6 of 9
(2,823 Views)
Accepted by topic author 22119823
I cannot open your vi because I don't have LV2020, however I guess you can manage the Timeout error from the UDP Read function.
Can't you?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 7 of 9
(2,742 Views)
Thank you!
Message 8 of 9
(2,733 Views)
Hi number,
As I said before: handle the upstream error!
Message 9 of 9
(2,728 Views)
