Displaying indicators from a subVI into Main VI
I don't know why the data won't pass if the indicator is inside the Tab Control.  I got the same results you did.  If I move the indicator out of the tab control, I can access its data.  Maybe someone else here can explain how to access an indicator inside a tab through its reference.  Sorry, I don't deal with tab controls very much.
Aside from your problem, I notice your last name is Leach and your first initial is D.  I used to know a Denis Leach that hated Labview, he is a VB man.  I don't suppose that would be you.
Message Edited by tbob on 10-31-2006 01:48 PM
- tbob
Inventor of the WORM Global
Message 11 of 14
(767 Views)
Nope its Don -
I went ahead and incorporated all the upgrades into the real program.  Its a bit sluggish but it all works perfect from reading and transferring the rings, to the indicator lights, to strings and all.
Thanks a bunch Tbob!
LV7.1, LV8.5, LV2014/15/16
Message 12 of 14
(755 Views)
I'm coming in a littel late here and the VI is a bit confusing but just doing Controls[ ] property will not give you the controls on a tab. You need to get the reference to the tab and proceed from there. See if the posting here and the example helps.
Message 13 of 14
(755 Views)
So that's how a control ref is obtained from a Tab.  Thanx a bunch Dennis, I learned something new today.
- tbob
Message 14 of 14
(746 Views)
