Displaying m by n arrays on a 2-D table
I have an m by n array generated by two nested for loops where the inner for loop has two values (columns) I wish to display, and the outer for loop has one value I would like to display. The C code equivalent of my VI would be:
for (Pin = Pstart; Pin < Pstop; P++)
for(freq = start; freq < end; freq = freq + iterator)
Read "Pout" from instrument
Thus I want to display a 2D table consisting of values:
Pin freq Pout
0 1 2
0 2 2.2
0 3 2.1
1 1 3
1 2 3.1
1 3 3.3
(2,602 Views)
Pin freq Pout
0 1 2
0 2 2.2
0 3 2.1
1 1 3
1 2 3.1
1 3 3.3
On the diagram, right-click the output of the outer loop, and create an indicator. LV will create a 2D array for your results. If you need a "table" instead of an array, then you have first to convert the numeric values to strings, and then you can use a 2D table (in "List & Table" sub-palette
CC
Chilly Charly    (aka CC)
(2,597 Views)
Thank you
(2,582 Views)
