Displaying regional language(Tamil) in VI FP
Dear All,
I would like to display the control and indicators labels in Tamil language. is there any way to do this. ? i have tried using installing of .ttf files. Tamil letters are visible in MS word. but when i am copying into VI FP it shows only question mark symbols(????).
Any help..!!!
(3,422 Views)
Hi azadplc,
you need to read about Unicode support in LabVIEW.
You may start here
(3,403 Views)
Accepted by topic author azadplc007
Thank you GerdW.
I just finish my requirement using below steps....
1. I used only UseUnicode=TRUE at the end of the LabVIEW configuration file LabVIEW.ini located at C:\Program Files\National Instruments\LabVIEW this step...
2. I copied the Tamil words from google translate and i paste it in notepad file. while saving the file make sure that "Encoding" format is "Unicode". Then read in VI. Finally, right click the String Indicator & enable Force Unicode Text.
for more details, pl visit below link
https://forums.ni.com/t5/LabVIEW/Display-Text-in-Hindi-Language/m-p/3830510#M1083343
(3,395 Views)
