Hello Todd,
but be aware that (at least) some of these properties can't be accessed when you compile your application...
I had a similar problem (checking the version/revision of several measurement systems and warn the user, if
there is a new version) and solved it that way: write your revision information in the vi properties. Then run
your vi, read the rev.text and wire it to a string indicator. After running the vi make the current value of the
indicator the default value. When you compile your vi (or whole project) then you can include a check for the
execution system (development system or execution). Depending on that check you can get your data from the
vi properties or from that indicator.
