Displaying several windows of a file on a tdms labview graphic
Hello I have a problem with the data reads a tdms file. Here I make noise measurements and I get it all with microphones and I make N times. So I recorded everything in a file tdms and separated me the measurements of N times in N windows. My problem is that when I open the file I want to view the data on a graph of N measurements, I am able to read the first window, so that the first N. M'interresse me what this is all the curves of N times. If someone would have an idea how could I do that would be great !!! I thank you in advance.
(3,024 Views)
Do you have an example TDMS file so that we can better understand what you have?
(3,017 Views)
Hello
Sorry for the late response.
I leave it attached an example file I tdms.
Thank you for your reply.
(2,968 Views)
