Displaying slide position real-time in a 1D Array
Hi!
I'm trying to create arrays when I don't know the size prior to creation. For the first step I'm trying to get the current position of a slider and put it to a 1D array. My problem is, that the while loop overwrites the first element of the array instead inserting the new value to the end of the array.
The diagram so far:
RT_position
Message 1 of 10
(3,917 Views)
Right click on the tunnel between the slide control and the array and select enable indexing. Connect the output of the while loop directly to the array indicator (remove the build array fuction).
Ben64
Message 2 of 10
(3,910 Views)
Short answer: Remove the "built array" node and make the inner output tunnel autoindexing. (but keep reading!)
Long answer: Still, this is very bad code, because you will run out of memory in seconds. Either use an inner FOR loop with a limited number of iterations or place a significant wait inside the inner loop. It is typically not a good idea to grow arrays indefinitely. What exactly are you trying to do?
Message 3 of 10
(3,908 Views)
Still the first element of the array changes only.
My aim is to get the position of the slider to the array when I press the OK button. Kind of getting a "sample".
Message 4 of 10
(3,906 Views)
Accepted by topic author PierreBatka
Actually, looking at your code once more, it seems you want to grow the array inside the outer loop. Place a shift regsiter on the outer loop and use "built array" with the upper connector coming from the left shift register and the lower connector coming from the slide. The output goes into the right shift register. Initialize the shift register with an empty array.
Use an event structure instead of the inner loop.
Message 5 of 10
(3,903 Views)
This is a part of a large project the final aim is to log the position of the moving part of an instrument in every x sec. The problem is that the logging will take as much time as necessary for the operator to solve a task, so I cannot say how long the array will be.
I am aware of the possible memory losses, still I don't have a better idea.
Basically I would be content if I could create any of the following:
1: Getting the position of the slider on button press, and writing it to the end of the array.
2: On button press get the position of the slider with a preset sampling frequency and putting it to the array, until the button is pressed again.
Message 6 of 10
(3,894 Views)
Did you try my suggestion above?
Message 7 of 10
(3,884 Views)
I did. It was an advance, so thank you, but I don't know if I can give any condition to the event structure (it should be active only if I switch the button from OFF to ON), and can I specify some kind of sampling frequency?
Anyway thank you for you help!
Message 8 of 10
(3,878 Views)
Here's a quick example (LV 8.5) using "elapsed time". Modify as needed.
Message 9 of 10
(3,865 Views)
Perfect. Thank you very much, I've learned a bunch of things about LabView.
Message 10 of 10
(3,846 Views)
