Distance between two minimum
Hi everyone,
the file below represents my incomplete code. How can i find the distance between the two minimum of my interpolated curve (represented in the image below)?
Message 1 of 9
(5,272 Views)
Hi IIDama,
so you have a polynomial and want to know its minima?
Usually you differentiate the polynomial to calculate the min/max points:
y = sum( a_i * x^i) will differentiated to y' = sum (a_i * i * x^i-1).
As you know the polynomial coefficients it should be quite easy to calculate!
Message 2 of 9
(5,255 Views)
You can use the Peak Detector.vi and set it to detect valleys. It will give you the location of the valleys found. You may have to do a bit of interpretation but it is well explained in the help file.
Ben64
Message 3 of 9
(5,214 Views)
Hi ben64,
i've already tried to use Peak Detector but my problem is that i don't know how to connect it to my code. Can you help me?
Message 4 of 9
(5,179 Views)
Hi IIDama,
Have you tried it as simple as this?
(It might work better once you use a real waveform and provide usable settings at the other inputs of the PeakDetector!)
Message 5 of 9
(5,176 Views)
I want to find the minimum from an XYGraph, this solution doesn't work for it.
Message 6 of 9
(5,170 Views)
Don't do it on the XY Graph, use it on the Waveform Graph. Then you can retrieve the corresponding points on the XY Graph. Have you set the peaks/valleys input to valleys? set a threshold (and tried different values)?
Ben64
Message 7 of 9
(5,165 Views)
I can't, look at my code!
Message 8 of 9
(5,156 Views)
Hi IIDama,
Why can't you? With all the suggestions you already got?
You got your plot of the polynom. Create a waveform with the data of this plot. Feed the waveform into PeakDetector. Set the parameters for PeakDetector and you will get the desired results!
Message 9 of 9
(5,151 Views)
