Distint no of changes in real time data
Hi I am taking in data in real time where the value goes from 1009 , 1008 o 1007 to 0. I am trying to count the number of distinct times this occurs , for example the snippet below is should count 2 distinct periods of change.
1008
1009
1008
0
0
0
1008
1007
1008
1008
1009
9
0
0
1009
1008
have written a for loop as below but I cant figure out if the logic is correct as I get multiple increments instead of just the one
if(current != previous && current < 100)
x++;
else
x = x;
(3,597 Views)
Accepted by topic author zain1612
Hi zain,
problems: use of the formula node in conjunction with array inputs…
Why don't you use simple LabVIEW functions?
(3,580 Views)
Your statement here and your statement in the code is different. Here you say:
 But, the node in the code is:
if(R<100 & R1[ != 0)
I think your problem might be that your "x" value doesn't get fed back in to the node from the previous iteration. So when you put "x++", I think it still just has the initial value of x and adds 1. I'm not an expert on formula nodes, though, so I can't be sure about that.
I ran through a few different options to find the data shifts that you're working with. The top is the fastest, but requires you to have an array of values all ready to go. The bottom is closer to how your node behaves. Take a look:
 P.S. This snippet above can be dragged on to a LabVIEW block diagram to import the code.
Cheers
(3,550 Views)
I am a complete beginner , used to text based languages so its easier for me.
What is the name of *---> symbol as I am having trouble finding it
(3,535 Views)
I think I just forgot to save it when I made the change. I cant seem to drag it since I am using labview 13
(3,526 Views)
Hi zain,
it's a Feedback Node…
NI offers a lot of beginner courses to learn LabVIEW…
(3,520 Views)
