Distributing VISA Applications
An application with VISA serial calls fails to run correctly as a stand-alone
executable on a machine without LabVIEW installed. The run time engine is
correctly installed. The errors are invalid visa references. What do I
need to add to the build to allow visa apps to run?
(2,870 Views)
Chris Burak wrote in message
39c27140@newsgroups.ni.com...
stand-alone
Don,t worry you only need to install NI VISA RunTime (you can find it on the
LabVIEW CD)
(2,870 Views)
