Dividing 2 anologue input variables FPGA
Hi for all,
i wana implement shematic controller 2 loop
the inner loop  need  to explain set point expression
the probléme its wiring  types because variable are note similar type so i used different converter blocs but don't function what type of convert i must use to set point with division of 2 analog input from FPGA
(4,746 Views)
Just when you were thinking that nothing could be more more useless for troubleshooting than a screenshot... A picture from your phone? Really? And with the flash on yet...
Mike...
PS: CODE. We need to see code.
Certified LabVIEW Architect
LabVIEW Champion
(4,724 Views)
my problem is conformity of types after division of 2 input 16 bits integer to set point  type f regulator thanks
(4,696 Views)
You will need to convert to fixed point numbers to perform the divide.
If you drop a to fixed point on each of the inputs it "should" (but check) convert it to a 16,16 fixed point number which means you don't lose any data but the divide will work.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(4,670 Views)
please some precision in your responce  i'am not expert so you want to say i add 2 converter to fixed point before dividing opération !
for your second solution  after dividing i integrate converter ?!! thanks.
(4,633 Views)
Hi Rayden,
I believe James Mc was suggesting that you should try to convert each input (Ubus and Ucapa) to fixed point before dividing, instead of converting after division.
Try that and let us know how it works out.
Lauren
(4,577 Views)
Hi Rayden,
Yes exactly as Lauren said.
We need a number type that can have a fractional part for divide since even if you start with integers you can get a non-integer result. By converting to fixed point before the divide then the output will automatically be a fixed point number which can store the result.
Cheers,
James
James Mc
(4,550 Views)
