Dlls working fine in LabVIEW 6.1 dont do so in LabVIEW 7.0
We are using the following dlls from Microstar Labs for one of our
Microstar DSP boards :
a. DAPIO32.dll : DAPcell client I/O library
b. Diostub.dll
We use these in the main Vi called DAPControl.vi
We currently run this VI in LV 6.1 - its working fine for the last several months. When we open this VI in LV 7.0 the VI loads (i.e. there is no problem reported by LV as far any subvi/dll is concerned), but during run time it gives an error. Specifically the Function DAPLinePut does not work - when trying to input offset values & set display.
(2,535 Views)
Hello MKris,
Thank you for your question regarding executing a VI written in LabVIEW 6.1on LabVIEW 7. You mentioned that the VI executes correctly in LV6.1 but gives an error when executed in LV7. I am not familiar with the functions of Microstar you are using and I might be more equipped to help solve your problem with some more information about the problem that you are having. Could you possibly provide a screen shot of the error or some sample code that demonstrates the problem in the simplest way possible?
Shea C.
Applications Engineering
(2,535 Views)
