Do Controls/Indicators in all display tabs get updated even if not visible?
At 38400 you can get ~3840 characters/sec, or ~77 per 20ms. If sending a command and awaiting response it's better assume 50%, or ~40 chars per 20ms. How much is sent and recieved, is it even possible at this speed?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(474 Views)
Thanks for the feed back. I have another idea that might work. I could take all the display data and put it in several clusters and then route those clusters to a parallel loop that updates the terminals every half second or so. Do you think that would work?
Also to answer some of the other questions.
1. there are only 10 bytes in each message.
2. I am not using synchronous displays
3. I have updated the priority of my vi. Thanks, I didn't know I could do that.
Message 12 of 13
(469 Views)
Hey, if nothing else, I'm consistent! 🙂
I just don't like complications and tabs (besides often not working as intended) complicate things.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 13
(467 Views)
