Do I have rights to burn a DVD with NI-DAQ 7.3, NI-488.2 and my app. in LabView ?
I was woudering if I needed a special request to burn a DVD with my drivers and my application in LabView 7.1. I have a licence for LabView 7.1.
Many thanks,
Have a great day,
Philippe
(3,050 Views)
By "app" do you mean you have the Application Builder? If so the SW agreement is quite specific and the answer is yes...
Application Builder license agreement:
12. Application Deployment. You may distribute or otherwise make available Authorized Applications (including applicable runtime engines for the SOFTWARE and applicable driver interface SOFTWARE that you may include as part of or together with your Authorized Applications) provided you comply with each of the requirements set forth in sub-sections (A) and (B) below:
(see section 12 for full details)
I think the same guidelines are used even if this is just a VI and drivers...
(3,046 Views)
What DVD are you burning? If duplicating a DVD, some DVDs have copyrights and it is not lawfull to copy those. If creating your own, then there should be no worry.
- tbob
Inventor of the WORM Global
(3,043 Views)
yes, I am creating my own DVD with drivers and my own VI interface. I guess I have the rights then.
Many thanks,
Phil
(3,026 Views)
Hi Chaos,
thank you for the tip.
Have a nice day,
Phil
(3,018 Views)
