12-06-2007 05:34 PM
12-06-2007 05:35 PM
12-07-2007 11:11 AM
12-07-2007 02:27 PM
Hey Nickerbocker,
The Knowledge base you found was an article that I was also looking at. It looks like if you had the DSC module, you could accomplish what you are looking for. Are looking to possibly acquire the DSC module?
I will see if I can find any documentation that can help you out.
Kevin H
12-07-2007 03:16 PM
12-07-2007 03:38 PM
12-13-2007 03:05 PM
12-13-2007 03:06 PM
12-14-2007 03:50 PM
No, it should not be involved at all.
Yes, it is going to need to included with the installer.
Can you please give a little more information here? I'm not quite sure if I understand your question.
Can you please explain this a little more as well? If I understand you correctly, it sounds like you have many datasockets open in one while loop. Are you using one datasocket per variable?
Shared variables are in general more easier to use, and provide a simple way to implement the idea of passing data between machines. Obviously, using TCP, you can create more control using your own protocol to exchange information, but in general, Shared Variables are normally just easier to use.
Feel free to post any questions or dicussion issues here.
Kevin H
12-19-2007 03:59 AM
