Do I have to dequeue each element separately?
I am still a little confused about what you are actually seeing. Can you post a small data file which shows the effect? also tell us what you expect or what you thought you should get.
Lynn
Message 31 of 32
(618 Views)
I attached an excel file with the data. I had to delete about 2000 row though, but you can see on the first sheet the amont of data that was collected for each column and then on the second sheet if you scroll to the right to the event column section you can see that the time stamp on the event descrip does not match with that rows time stamp from the data.
Message 32 of 32
(603 Views)
