Do I need DSC module
I have Dewesoft DAQ system for measuring "things". Dewesoft runs DCOM server on my local PC. I'd like to use LabView to read these "things" that I'm measuring. I have LabView 2017 Professional.
Just a simple question: Do I need DSC module to be able to read data from DCOM server?
Thanks.
(1,739 Views)
Hi Waltteri,
DCOM is published as OPC data; you can see here for how to develop OPC Clients in LabVIEW: https://www.ni.com/docs/en-US/bundle/labview/page/developing-opc-clients-in-labview-windows-only.htm...
LabVIEW DataSockets might be available for you if you meet the requirements on there, but I would assume you have more OPC data references than the limitations. In this case, DSC will be required.
Cheers,
Nick
(1,680 Views)
