Do I need a semaphore to control adding elements to a queue?
I am developing a GUI which has several sub-GUIs running concurrently.  I would like to be able to have all GUIs record to the same log file.  To do this I am considering using a queue so that each sub-gui can queue log messages while one VI will record them to the log file as they are received.  Will I be able to enqueue messages from various sources without using a semaphore?  (Will something bad happen if two VIs try to write to enqueue an element at the same time)?
Thanks!
Jorge
(3,180 Views)
There is no need to use a semaphore or any other technique to protect the access to the Enqueue Element function.
(3,164 Views)
Thanks!
(3,154 Views)
Also remember that elements are typically dequeued in the order they were entered into the queue.  Not from where it was entered.
It is usually a FIFO.  It doesn't matter which sub-vi or loop it came from.
RayR
(3,135 Views)
