Do I need the FPGA Module if I am just accessing a Bitfile?
Obviously I need something, because my program will not load the bitfile. Seems like there should be a way to access the "host" side of the FPGA, i.e. access the bitfile, without having full-blown FPGA Module installed. On this particular machine, I don't want to do any FPGA programing, I just want to use the FPGA as a "black box".
(2,296 Views)
Accepted by topic author rds2112
This is definitely possible.
See https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/lvfpgahosthelp/interface_no_module.htm...
Depending on which device you are using, see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHPfCAO&l=en-US
I think you may just need the drivers (e.g., FlexRIO, R Series) for the board you are using. Which board are you using?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,287 Views)
Thanks for you help. The FPGA is a PXIe-7857 and the controller is a PXIe-8861. When I load the program, it's trying to find the things in the attached.
edit: the things done in the links you provided are known and have been done. The bitfile has been made and accessed and has been working for a few years. My question is more on the lines of: "what must I install to get THAT stuff to work, hoping its not the full-blown FPGA Module.".
(2,224 Views)
That is an R-Series board, so you will need the NI R Series Multifunction RIO Driver.  Just find that version that works with your version of LabVIEW.
(2,214 Views)
Thanks all. It was indeed only the drivers that I needed. The confusion was that the drivers WERE installed, yet LabVIEW on my newly built machine wasn't giving me the FPGA interface nodes. The issue, I guess, was a broken installation of the drivers. I re-installed and, with no other work besides the re-install, everything is now working.
(2,191 Views)
