Do I need to activate Labview software before Math Script will work?
I installed Labview 2010 on my computer to play around with and learn how to use it before we install it on the computer that will actually use it.  I have not activated it because that would limit it's use to this computer unless we bought another license.  I want to create a Mathscript node to do some calculations but it is not showing up.  I am also unable to find the Mathscript Window in the Tools menu.  Is this because I have not activated my software?  Do I need to activate to use the Mathscript features?  Or do I need an additional add-on?
(3,218 Views)
Hi Depthcharge623,
To use the MathScript node, you'll need to download and install the MathScript RT Module. This can run in evaluation mode along with LabVIEW.
Hope that helps!
Andy H.
(3,191 Views)
