Sara2004 wrote:
> Thanks for your response. This is good to know. I'm assuming the same
> is true for MSWord and MSExcel report refnums...is this a correct
> assumption?
You should generally close any refnum. LabVIEW 7 does have improvements
to its own refnums (App and VI refnums, Control refnums) which does not
require to close them anymore but doing so will definitly not hurt.
For Active X refnums, in the best case they just use up memory until you
close the entire application or the LabVIEW development system. In the
worst case the system can crash when you close the executable or LabVIEW
due to the Active X component stumbling over left open object references
when Windows forces those objects to be closed on behalve of the leaving
execu
table.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
