Do U have a simple and intelligent solution for this problem? Logical problem...
I have explain what I need... maybe it's better if I do example?
Message 11 of 15
(778 Views)
Michelle1892773 wrote:
Not very good... I hope excellent solution 😉
<...> please save it for previous version of LabView. I don't have LW9.
How have you known if my solution is not "excelent" then? 😄
Okay, do an example. Maybe somebody will manage to help you 😉
Message Edited by Giedrius.S on 02-20-2010 12:32 AM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
Message 12 of 15
(775 Views)
Yes.  As I said, either explain how Giedrius' solution is not right for you, or do your own work and post back if you have problems with how that works.
Message 13 of 15
(755 Views)
I write the steps of the cycle, X is the variable that cycle modify, N is the random number that the cycle generate:
X=50;
N=24;
i=0:
      N(0)=83;
      N(0)<N;  (START WITH +, IF START WITH - CHANGE + WITH - AFTER)
      X(0)=50+1=51;
i=1:
      N(1)=72;
      N(1)<N(0); (YES, SAME OPERATION OF PREVIOUS STEP:+)
      X(1)=51+1=52;
i=2:
      N(2)=69;
      N(2)<N(1); (YES, SAME OPERATION OF PREVIOUS STEP:+)
      X(2)=52+1=53;
i=3:
      N(3)=98;
      N(3)<N(2); (NO, CHANGE OPERATION:-)
      X(3)=53-1=52;
i=4:
      N(4)=19;
      N(4)<N(3); (YES, SAME OPERATION OF PREVIOUS STEP:-)
      X(4)=52-1=51;
i=5:
      N(5)=77;
      N(5)<N(4); (NO, CHANGE OPERATION:+)
      X(5)= 51+1=52;
CONDITION OF END: THERE ARE 2 CHANGE CONSECUTIVE.
Message Edited by Michelle1892773 on 02-19-2010 04:57 PM
Message Edited by Michelle1892773 on 02-19-2010 04:58 PM
Message 14 of 15
(753 Views)
