Do front panel property nodes characteristics differ between operating systems
Yes,
Im just getting into labview, it seems very difficult to keep clean at times. Im getting the hang of it though.  I actually found the solution as well.  I renamed the module on my computer and i have that as a constant in the application, so ofcourse when i switched to the other computer it couldnt find the correct moduel.  It works now, but is there a way to hard code something like that so i wouldnt have the issue if i was to deploy it?  Also any advice on my code is always welcome. Im trying to make improvements.
Thanks James,
Matt
-Matt
Message 11 of 25
(1,424 Views)
Glad you found the problem.
When you say Module, you mean the instrument module, right? So the name that shows in your DAQmx channel? I don't think you shared the right code above because I don't see anything like your horizontal/vertical scrollbar image you sent.
If it's a DAQmx module, you can create a configuration file from MAX that includes that device's alias and everything and then include that with an installer along with the executable. Other options are to find all DAQmx resources that are connected, sort by what type of instrument they are, and use the one that matches what you want. I worked with a Network DAQ before and I knew that no other NI9191 devices would ever be on the same network so I just found all 9191 devices and use the "first" one.
Cheers
Message 12 of 25
(1,416 Views)
James,
That was the right code, in the second tab you should be able to see the array and scroll bar, it may open with the graph up and you may have to run it to make the tab control visible  I will look into the configuration file and may just try to use the serial number of the device, i know that wont be changing.
I appreciate the help,
Matt
-Matt
Message 13 of 25
(1,410 Views)
Are you sure?  The only VI I've seen attached is called Thermocouple Testing.VI.  The only thing I see on your front panel is a waveform chart and a stop button.
Message 14 of 25
(1,389 Views)
Ravensfan,
Thats how i mustve saved it, if you run the code, it should go to the correct front panel.  The tab control isnt currently visible, that the front panel it ends on, which i should probably have it return to the start front panel. Here is the same Vi just saved at the start state of the front panel.
-Matt
Message 15 of 25
(1,384 Views)
I'm just on my phone now, but there is a subVI missing I believe, so we can't run the code.
Cheers
Message 16 of 25
(1,374 Views)
Thats odd,
Does it say which vi is missing? I dont have any user vi's in the application, nor any add on vi's.
-Matt
Message 17 of 25
(1,359 Views)
@matt198717 wrote:
Thats odd,
It is a ctrl:
"ENUM RING FOR TEMPERATIRE.ctl"
Message 18 of 25
(1,335 Views)
Oh that's right, now I remember that. Blokk, can you disconnect those type defs and run the code to see what OP is talking about?
Cheers
Message 19 of 25
(1,327 Views)
Okay,
I got it.  Im sending the project file now, this is all learning experienc for me.
-Matt
Message 20 of 25
(1,326 Views)
