Do nothing in case structure with For Loop
Hi
 I am trying to extract some data from my signal (0.3 0.4 0.6 ...). I want to extract values that is larger than 0.5 and put it into an array. So i am using a For Loop which i can determine each index of my data to be compared and passed it into the case structure. In the "True"  box i wanted the value to be extracted outside the For Loop Box. And i want to "Do Nothing" if my value falls into the "False" Box. However, this would show error, saying " Tunnel : Missing assignment to tunnel".
I tried to select "Use Default" but it do not work since i am using a Boolean comparison. I tried to use Shift Register but to no avail too.
Could anyone guide me on this to extract only value larger than 0.5  and their index??
 For Example "0.6 0.7 0.8 ; index 3 4 7"
Great Appreciation will be given.
Message 1 of 10
(9,814 Views)
Use the Build Array with Shift Register to Build the Table.
Message Edited by Eugen Graf on 12-09-2009 05:39 AM
Message 2 of 10
(9,812 Views)
Message 3 of 10
(9,798 Views)
Thank you Eugen. This is very helpful. Just one question is that the index of values is automated ? And could you supply me with the VI ?
Message 4 of 10
(9,789 Views)
Your Table will be compressed, index will automaticaly grow.
Which LabVIEW Version do you use?
Message 5 of 10
(9,787 Views)
Hi i am using 8.6.1
Message 6 of 10
(9,783 Views)
Accepted by topic author pengxin
Message 7 of 10
(9,769 Views)
This looks like a job for the Code Capture Tool's new VI Snippet feature!
Jim
Message 8 of 10
(9,768 Views)
Thank you once again Eugen
Message 9 of 10
(9,743 Views)
This solution this saved me. Thanks...
Message 10 of 10
(7,791 Views)
