Do the Tektronix driver subVIs have similar funcitions and connector panes as that of the Le Croy oscilloscope?
Hey everyone,
Message 1 of 8
(3,154 Views)
Best scenario would be the set of IEEE488.2 functions, which are limited compared to the "extensions" most manufacturers add.  I believe Tektronix drivers follow the standard. Never heard of LeCroy.
Message 2 of 8
(3,151 Views)
@Queen wrote:
Hey everyone,
You can find out by downloading both drivers and LOOKING.
This thread is a continuation of one started by the OP earlier  http://forums.ni.com/t5/LabVIEW/Labview-conversion-from-Le-croy-to-tektronix-Oscilloscope/m-p/223040...
Message 3 of 8
(3,124 Views)
Thanks Bill, that is probably the most helpful reply so far!
Message 4 of 8
(3,120 Views)
nyc, if you have no helpful reply please stay away from my threads!
Message 5 of 8
(3,119 Views)
Have you even looked at the driver VIs for both scopes?????
I don't understand how you expect to accomplish anything by just "talking" about something.
Message 6 of 8
(3,110 Views)
I am in the process of doing so! again you're not helping by being aggressive...I really I don't understand what problem you have but you need to work on your replies!
Message 7 of 8
(3,105 Views)
I don't have a "problem".
What is important for you to understand is that this is not a trivial task.
You write as if you expect it to be such.
Asking what is essentially the same question twice does you no favors.
Message 8 of 8
(3,102 Views)
