Do the inport pins 10 - 13 have internal pull up resistors?
IEEE 1284 25 pins parallel port......Do all the inport pins 10 - 13 have internal pull up resistors?
(2,491 Views)
I don't know for sure but I suspect that it would depend on the manufacturer and type of the transceiver IC used. I don't have access to the IEEE spec. If you do, what does it say about required terminations?
(2,479 Views)
