Do you require device drivers (ie Gaili card drivers or ESD CAN bus drivers) just to build a LabVIEW application
I have be told a number of different things in regards to this.  Some say that you need the device drivers to build and some say you do not.  I think that there are no interaction with the device drivers to build the application, but if there are library files then all you need is the library files.  Any comments.
Rob
(2,546 Views)
Rob
Well if the device driver consists of DLLs you won't be able to compile and therefore link and build the application without those DLLs being available on the computer you want to do the build.
But your question does by far not contain enough detailed information to give more specific advice.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,544 Views)
