Does 64-bit DLL ready for NI DAQmx?
Dear Sir,
Could I develop 64-bit application in LabVIEW?
please give me the web pages for further understanding,
Thank you,
(3,105 Views)
LabVIEW is a 32 bit application and runs in the 32 bit Windows subsystem when you install it on a 64 bit Windows OS. As such it can't load or otherwise use any 64 bit DLLs.
I believe the best solution would be to recompile your DLL as a 32 bit DLL and load that into LabVIEW. Also, have a look at the following KB article:
Are National Instruments Products Compatible with 64-bit Windows XP x64 Operating Systems?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,091 Views)
Thanks Adnan,
Do you know when DAQmx could be ready for developing 64-bit applicaiton?
I am using Visual C++ with DAQmx API now and need 64-dll library for my experiement.
(3,065 Views)
(3,056 Views)
It also depends on the market and what's going on out there. If there is a business need, NI will definitely jump on it. I would recommend posting on the Product Suggestion Center.
Adnan Zafar
(3,043 Views)
