Does Anybody have labview drivers to program an MSP430 via SERIAL PORT?
Hello David. I'm also using the eZ430 with connectivity to the PC and also have the eZ430-RF-2500 kit.  Can I also use your VIs to see if I can adapt your code to program them through the USB interface? My email address ayomide.longe@mavs.uta.edu.
Thank you.
Message 41 of 60
(2,298 Views)
Hello David, I want to use Labview to use the MSP430 Launchpad as is done with the Arduino. Is that you could help me? Thank you. lalqaeh@ebuyclub.com
Message 42 of 60
(2,266 Views)
Hi David
Is it possible that you can send the application for the MSP430 to my e-mail address below.
E-mail:carreraa8@gmail.com
Thank you.
Regards
Alejandro
Message 43 of 60
(2,188 Views)
Hi David,
I just found this post while searching online. Would you mind sending me your labview soure code for Serial port to program MSP430 also?
My email is: ann_lungay@yahoo.com
Hope you'll get in touch. Thank you so much!
Message 44 of 60
(2,148 Views)
Ann and Alejandro,
sent you each an email with a zip archive attached.  Please let me know you received it.
Dave
P.S. Alejandro - sorry this is so late in getting to you.  I missed your post from last month.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 45 of 60
(2,130 Views)
thank you so much David!
Message 46 of 60
(2,117 Views)
Hi David,
Could you me your labview soure code for Serial port to program MSP430 ?
Here is my email: tintin_monster@yahoo.co.uk
Message 47 of 60
(2,061 Views)
Hi David,
Would you mind sending me your labview source code for Serial port to program MSP430 also?
My email is: cti_inc@hotmail.com
Shawn
Message 48 of 60
(2,060 Views)
Hello Dave,
I would also appreciate a copy of the driver for programming the MSP430 via serial port. I am using the ez430 rf2500 kit to wirelessly transmit and receiver sensor readings. Thanks for being a nice guy Smiley Happy
Zack
zkoontz3@gmail.com
Message 49 of 60
(1,993 Views)
There is no special driver like this but you see all the programming is done using command like arguments. Once you know command, argument and syntax then using system exec you can do all this in labview. May be you need to talk to text guys for that
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 50 of 60
(1,989 Views)
