Does Control Panel = Control Palette?
Is the control panel the same thing as the control pallete?  If it is where do I find the add/remove software tab?  Thank you!
(4,020 Views)
No. The Control Panel is a Windows thing. The Control Palette is inside of LabVIEW. I'm guessing you haven't used Windows much, like you're either just getting started with computers or coming from a different OS. The Control Panel is accessed from the Start menu at the bottom left of your desktop. Select Start->Control Panel. At that point if you're in Category view click on the "Add/Remove Programs" link. If you're in Classic view you'll see individual icons for each control panel applet. Double-click on "Add/Remove Programs".
Just a suggestion: you may want to pick up a cheap book on Windows.
(4,009 Views)
No.
Ben
Message Edited by Ben on 06-29-2007 09:37 AM
(4,009 Views)
no, control pallate contains the indicators,control and user interface options. whereas the control panel is the gateway for managing the windows options.
(3,997 Views)
check the labVIEW fundamentals for furhtur details
(3,994 Views)
OT:
Ben:
Nice "firewall" residing right on your desktopwink smiley
-AK2DM
(3,990 Views)
