Does IMAQ Readfile dellocate existing memory before reading?
I'm calling IMAQ Readfile in a loop, reading a different image each iteration. I am assuming that Readfile deallocates all image memory previously read before reading new data. Is this correct?
Thank you.
(2,699 Views)
Ron,
It should because the memory is allocated by the create call.  To be sure, put it in a loop and watch Windows Task Manager.  In thre process tab you can make sure that your application  is not growing.  It will bounce around but shouldn't be constantly growing.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(2,688 Views)
