Does Instrument I/O Assistant only work in the activated version of LabView 8.0 and not in evaluation version?
I'm using the LabVIEW 8.0 evaluation CD and every time I try using the Instrument I/O Assistant I get this error message "Measurement and Automation Explorer or the Instrument I/O Assistant is not installed correctly. Please install these from the LabVIEW Driver CD." So I tried installing both from the Device Driver CD and still it didn't work. I also tried uninstalling all NI softwares and components and reinstalled everything from the LabVIEW evaluation CD and Device Driver CD and still the same result.
I was wondering maybe the Instrument I/O Assistant will only work after I activate LabVIEW. Is this the reason why I can't use it or does Instrument I/O Assistant also work even if I'm only using the evaluation version? Please help!
(2,894 Views)
Hi!
Please try to install the II/O Assistant from the following download, this should help!
https://www.ni.com/en/support/downloads/drivers/download.instrument-i-o-assistant.html
Regards, Christian
(2,887 Views)
Glynster -
Yes, Instrument I/O Assistant does work with the evaluation version of LabVIEW 8.0.  However, you need to install Instrument I/O Assistant from a version of the National Instruments Device Driver CD that shipped with LabVIEW 8.0 (or later).
NOTE: The link provided for Instrument I/O Assistant 1.0.1 DOES NOT work with LabVIEW 8.0. It is only for LabVIEW 7.x.
You will need to obtain a Driver CD to get Instrument I/O Assistant to work with LabVIEW 8.0
-Tommy
(2,881 Views)
Glynster,
Please take a look at this link.  This is a Knowledgebase that I found searching www.ni.com/support.
Respectfully,
(2,867 Views)
Hi Christian. I tried downloading the II/OA 1.0.1 and it didn't help, but thanks anyway.
Tommy,
I don't have the Device Driver CD that came with the LabVIEW CD. So I sent an e-mail to NI Sales & Customer Support and asked for a copy. Thanks for your help and I will post the result when I'm done.
Thanks for the link Jeff!
(2,855 Views)
