Does Key Navigation work in sub panels?
I have tried to use Key Navigation in a sub panel without much luck. Please see the enclosed example. When running the keyfocus test vi by itself, hitting the enter key has the desired results. However, when run by the subpanel test vi, the enter key no longer works.
(3,702 Views)
I tried your VI. I did get it to work part of the way by clicking on the OK button and the key focus would change like it is suppose to that way but I could not get it to change just by hitting the enter key. However in the search that I did I found the templates.VI and I think this will point you in the right direction as to what you want to do. One thing that this Vi does is call a subvi called loadandrun.vi which allows you to put in the name of the control and the vi path where the control is located. maybe you can try this method. sorry I cannot be of any more assistance as I am limited in knowledge in this matter.
Joe.
"NOTHING IS EVER EASY"
(3,702 Views)
Here is a workaround.
(3,702 Views)
