Does LV IO Assistant work in Agilent 82357B GPIB USB
I understand how to have the Agilent 82357B GPIB USB work in Labview.
However, my interest is to use the LV's IO Assistant, does this one work under the said Agilent's GPIB-USB converter ?
Thank for help.
(2,638 Views)
Thanks for your question.
I have read your question and I have the following information for you.
First you have to complete the steps in the following document
Using HP Agilent 82357A/82357B GPIB in Measurement & Automation Explorer (MAX) or LabVIEW
http://digital.ni.com/public.nsf/allkb/F7C187DBF09EBE1186256F550065BD32
About the LV's IO Assistant, do you mean the Instrument I/O assistant?
You can use this assistant to communicate with message-based instruments and graphically parse the response
Please check the white paper bellow for more information.
Instrument I/O Assistant
http://www.ni.com/white-paper/14066/en
Does this answers your question?
Corné Westeneng
NI Netherlands
(2,605 Views)
Yes, I mean the Instrument I/O Assistant.
Thanks for your links.
I'll try to have the Instrument I/O Assistant work  with the Agilent GPIB>USB converter.
Peter.
(2,597 Views)
