Does LabVIEW have any kind of source control?
I want to use a source control tool such as git and svn.
Does LabVIEW have such a tool?
Message 1 of 11
(4,751 Views)
Hi icat,
            Yes.See these: (Sorry as GerdW pointed out not embedded in.)
            https://decibel.ni.com/content/docs/DOC-1681
            https://www.ni.com/docs/en-US/bundle/labview/page/configuring-labview-to-use-source-control.html
Thanks as kudos only:)
Message 2 of 11
(4,744 Views)
Hi iCat,
no, such a tool isn't embedded in LabVIEW.
But you're free to install your own. LabVIEW supports some of them off the shelf, see the options dialog for more information...
And NI provides a KB entry: here! [broken link removed; article no longer available]
Message 3 of 11
(4,743 Views)
Hey iCat,
I use Tortoise SVN.  It is very good and its free.
I use ProjectLocker to host my code.  They offer a free package for small projects.
Lewis Gear CLA
LabVIEW UAV
Message 4 of 11
(4,727 Views)
Which one between git and svn should I use?
Message 5 of 11
(4,722 Views)
It's your choice (and maybe personal preference)...
Message 6 of 11
(4,718 Views)
Hi!
I happily use Tortoise SVN.
There are a few issues when using source control with Labview.
Just a couple:
- vis contain also compiled code and so modifications (for example to a typedef) propagate to many files.
- it's not easy (with respect to text based languages) to compare different verisons of a file.
It's worth giving a look to this:
http://forums.ni.com/t5/LabVIEW/LabVIEW-and-Version-Source-Code-Control-blog-series/td-p/1726752
Marco
Message 7 of 11
(4,713 Views)
It seems that Tortoise SVN can do graphical diff & merge.
Is there any git software that can do graphical diff & merge?
Message 8 of 11
(4,707 Views)
Any source code control provider supports graphical diff&merge as long as you can call LVCompare.exe and LVMerge.exe from the provider.
As i understand, you already managed to configure this for SVN.
I would expect git to have the same possiblity, but i'm sorry that i cannot tell you how...
Norbert
Norbert
Expert: Geometry
Message 9 of 11
(4,699 Views)
Should be the same for GIT, if you use
TortoiseGit
http://code.google.com/p/tortoisegit/
I've never used it, so I'm not sure if it's as stable as TortoiseSVN....
Marco
Message 10 of 11
(4,691 Views)
