Does LabVIEW support Mobile and Wireless Protocols?
Does LabVIEW support these protocols;
3G     GSM        PHS
4G     HCSD        TACS
CDMA     HSDPA        TDMA
CDMA2000     iDEN        TD-SCDMA
EV-DO     Mobitex        UMTS
FDMA     NMT        WCDMA
GAN     PCS        WiDEN
GPRS     PDC        WiMAX
If it does (some or all) of these protocols, what do I need to install to get VIs supporting these protocols (I mean which packag/ toolkit etc contians supporting VIs/ functions etc)?
Thanks for your help!
Have a very pleasant day!
(3,626 Views)
Most of these protocals are OS-supported. LabVIEW doesn't have lower level interface VIs.
For instance LabVIEW doesn't build a TCP/IP stream with header and stuff, the OS TCP/IP stack deals with that stuff.
For testing the quality of such network there are special hardware (most PXI) and software solutions.
What is it that you want to achieve?
Ton
My LabVIEW Ideas
(3,621 Views)
Are you perhaps looking for the Modulation Toolkit?
(3,604 Views)
