Does LabVIEW support Shared Memory File created by VC++?
Can LabVIEW program read and write online data stored in a Shared Memory File created by a VC++ application using Windows SDK Functions: CreateFileMapping, OpenFileMapping, MapViewOfFile ... when both programs are running? If yes, how? What vis? Any examples?
Thank you very much.
Stars
Message 1 of 8
(6,343 Views)
Hello
LabVIEW doesnt have direct support for memory mapped files. The only way you would be able to set this up is via dll calls that call the functions. Check out the following manual for more information on how dll's work with LV.
Bilal Durrani
NI
Bilal Durrani
NI
Message 2 of 8
(6,343 Views)
I am having trouble trying to do this also. I have a c++ program that is creating and writing to a shared memory location. I know that it is working correctly becuase i read off that memory with several other apps. I tried writing a dll with the same read code, but Labview Crashes Everytime I run it.
Attached is a simple dll example i tried to trys to read one element out of and array.(The arrays has 40 elements.) Anyone have any suggestions? (This is just the read mind you.)
Message 3 of 8
(6,343 Views)
Hi
You're in luck. Just a few weeks ago I created VI's to read and write memory
mapped files!
I've tested it with interaction between several LV applications (.exe) and
mixed it with several instances of LV, and that worked fine (see thread
"Communitating Between Built LV App.s"). The VI's are there to download.
The difficult part is to get LV to write into memory. If you only want to
write a string, it's easy, but for data (with \00 in it) it's a bit more
difficult. Anyway, the VI's already have that functionality.
The VI's are written to interact between LV applications, but everything to
interact with other applications is in there. Perhaps some things turn up,
but I'm sure they are all solvable.
Wiebe.
"Stars" wrote in message
n
ews:50650000000800000058BF0000-1075935269000@exchange.ni.com...
> Stars
Message 4 of 8
(6,343 Views)
I am trying to find this thread but cannot find it with a search. Where exactly is it?? Thanks,
Dave
Message 5 of 8
(6,343 Views)
I accidentally send it as a new post, sorry for that. Here is the link to
the discussion:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000005BC10000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Communicating+Between+Built+LV+App&USEARCHCONTEXT_QUESTION_S=0
Wiebe.
"dirtyb15" wrote in message
news:506500000005000000DD660100-1078497998000@exchange.ni.com...
> Dave
Message 6 of 8
(6,343 Views)
Is there any actual thrad with the vis?
thx
Message 7 of 8
(5,617 Views)
I can't find the link. Can you re-post the link?
Message 8 of 8
(5,135 Views)
