Does LabVIEW support importing an XML file that describes an OPC UA Server Address Space
Does LabVIEW support a standard file format for configuring a server address space?
(2,947 Views)
Looking at the main paper for it, it looks like LabVIEW constructs OPC UA Server Address Spaces in a specific manner: http://www.ni.com/white-paper/14253/en#toc3
I don't know if you will be able to write an XML file to it directly. You may need to parse out the sections in accordance to how it currently writes.  But LabVIEW reads xml files so those functions should be available.
(2,922 Views)
I am looking for a built-in solution from NI.  The OPC Foundation specifies an XML import file format building address spaces.  I am wondering if LabVIEW supports the standard or an XML file format of their own design.
(2,909 Views)
