Does Labview experience ANY problems with Celerons??
Will Labview have any problems if installed on Celerons? if any, what are they?? and which version of Labview will have the problem?
(2,629 Views)
I have run several versions of LabVIEW on Celeron processors with no problem. The operating system is far more of a determining factor than the processor as far as compatibility. If you are running Win98, 2000, NT, or XP, you should be fine. Just make sure you have a decent video card and plenty of RAM.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,629 Views)
