Does Labview support BLE (Bluetooth low energy)? Any
I have TI - CC2541 Based custom hardware and wanted to use Labview to communicate the device via BLE (Bluetooth 4.0 Low Energy).
I have gone through many forums. Most says that they doesnt support, but looks lik all are very old forum.
Please help me on this.
Javahar
Message 1 of 8
(6,808 Views)
The question is wrong i feel. It is not LabVIEW what communicates directly with your BT device, but another BT device on your laptop/computer. So if we call your device "TI - CC2541 Based custom hardware" a client, what will you use as a BT host? A BT dongle connected via USB to your PC? Or a built-in BT in your laptop? So first you should be able to connect these two BT devices, and pair them only using your operation system. LabVIEW is the second step after this test.
edit: so explain it in a different way: If your OS supports the BT LowEnergy device, then LabVIEW should also work with it...
edit2: ok, it is indeed more complicated as I thought :)) I have found some fresh discussions on this topic by google:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Bluetooth-Low-Energy-BLE-support/idi-p/3080038
Message 2 of 8
(6,788 Views)
Hi javhar,
Did you manage to get around this problem?
Suzanne
Message 3 of 8
(6,423 Views)
Hi Javahar,
                         Labview API uses RFCOMM, which is a connection protocol exposed by winsock interface. If your OS supports this; you can connecct labview to the device.
https://www.ni.com/docs/en-US/bundle/labview/page/using-labview-with-wireless-devices.html#d43266e13...
Kamlesh
AE NI India
Message 4 of 8
(6,394 Views)
Hi Kamlesh1,
Do you know if Windows 8.1 or 10 support the winsock interface for BLE? I have broadcom wiced ble device with 5 temperature sensors on board. I want to transmit the sensor data to labview 2014. Is this possible?
Message 5 of 8
(6,380 Views)
After lots of research, the way that I found to access the BLE from Labview is via Linking Bluetooth DLL and using its API's.
Let me know, if there is any new hint available on this.
Javahar.R
Message 6 of 8
(6,361 Views)
Hi Javahar,
thanks for your response. Would you mind sharing your VI and maybe an outline of the method you had to use to link Bluetooth DLL using its API's? I am PhD student and struggling to get a broadcom wiced ble device to communicate sensor data to labview.
Suzanne
Message 7 of 8
(6,345 Views)
Hi Suzanne and Javahar,
                                               Please check it out this link: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LuHSAU&l=en-US
It clearly says that if you have OS supported for BLE communication; it will work. You can use functions exposed by "Microsoft BluetoothAPIs.dll" and for more info you can visit on this link: https://msdn.microsoft.com/en-us/library/windows/hardware/hh450825
Kamlesh
AE NI India
Message 8 of 8
(6,336 Views)
