Does Lock in amplifier kit work with DAQpad 6016
Hi all,
I have DAQPad 6016 (USB). I am trying to develope Lock in amplifier and I found Lock in Amplifier start up kit. So I am wondring that this tool kit works wit DAQ 6016? Moreover, DAQ 6016 does not support treditional DAQ. And this tool kit is with traditional DAQ so Can i change this traditional DAQ to DAQmx or any update available for Lock in amplifier start up kit?
Thank You
(2,492 Views)
Hi N.K.,
I found an example which is using DAQmx. Have a look at:
Multi Channel Count Lock-In Amplifier with DAQmx
Also please look here, because I the 6016 does sampling not simultaneous!
Lock-In Amplifier Startup Toolkit Compatibility with Non-DSA Hardware
 Andi
~~~ Logic is a systematic method of coming to the wrong conclusion with confidence ~~~
(2,487 Views)
