Does NI 9233 cDAQ module support analogue triggering?
I'm attempting to reduce the number of DAQ modules required for a drop tower system. Currently, a light gate triggers measurements to be taken via a 9401 cDAQ module (digital). I'm looking to perform a similar operation using the analogue 9233 module.
I'm trying to find out whether the NI 9233 module allows analogue triggering when used with the CompactDAQ chassis as opposed to the CompactRIO setup. I've looked in the datasheet, but all I seem to be able to find is the line "many advanced features may not apply when the module is used with CompactDAQ".
Any ideas?
Tim
CLA
(2,930 Views)
Hi Tim,
The NI 9233 does not support analog triggering in either the CompactRIO or CompactDAQ platforms.
Kyle
(2,928 Views)
Brilliant, thank you!
I have access to neither the module nor the documentation that comes with it at the moment, but at least I can design the VI for it.
CLA
(2,922 Views)
