Does NI-DAQmx 9.2.2 for USB 6251 work for labview 8.2?
Does NI-DAQmx 9.2.2 driver download for USB 6251 work for labview 8.2?
Thanks in advance
Message 1 of 8
(5,357 Views)
What a good question!  Too bad there isn't a convenient chart to show this kind of information... Smiley Mad
http://forums.ni.com/t5/LabVIEW/DAQmx-Version-for-LV-8-2-1-and-2010/td-p/1276594
However, the answer is no.  Smiley Sad DAQmx stops at 9.0.2 (maybe 9.1 but I think not) for LV 8.2.  That combination will still support the USB-6251 though. Smiley Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 8
(5,351 Views)
Accepted by topic author Hova
NI-DAQmx 9.1.1 was the last version to officially support LabVIEW 8.2
NIquist: I'm investigating as to why this KB seems to have vanished into thin air.  I can see it internally, but not externally.  I'll update the post you linked when I figure out what is wrong.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 3 of 8
(5,346 Views)
Do you know where I cold find the driver for LV 8.2?
Message 4 of 8
(5,343 Views)
Ok well I think it was just posted... Thanks!
Message 5 of 8
(5,339 Views)
Smiley HappySmiley HappySmiley Happy
BTW, I THINK the document that stated DAQmx9.1 would work with LV8.2 was in error.
EDIT: Just in case here's the link to 9.0.2 --  http://joule.ni.com/nidu/cds/view/p/id/1444/lang/en  (Sorry but they're both around 1 Gig downloads and rather slow to install.)
Message 6 of 8
(5,337 Views)
deleted
Message 7 of 8
(5,336 Views)
Support for LabVIEW versions gets added and dropped during our yearly "LabVIEW" DAQmx release.  These come "on the fives", much like your morning traffic report.  NI-DAQmx 8.9.5 added LabVIEW 2009 and dropped 7.1.  NI-DAQmx 9.1.5 added LabVIEW 2010 and dropped 8.2.  Anything between X.X.5 releases should maintain constant LabVIEW support.
Seth B.
Message 8 of 8
(5,327 Views)
