Does 'Read Lines' option for 'Read from Text File' function work on PDA?
Hi Subhashini,
The first thing I want to mention is that everytime you use a While Loop, you should always include an option to stop it with a stop button, rather than just the status of the error wire.  If you do not do this, the VI will run continuously if it does not read an error, and you will have no way of stopping the VI.  You will then need to shut down and restart your PDA.
Also, I see that you are using the One-Button Dialog Box VI to display each string.  To do this properly, I would suggest using a For Loop rather than a While Loop, and set the N terminal of the For Loop to the number of lines to read.  This way, the VI will display a dialog box for each line, and then the VI will stop.  I've included an edited version of your example that uses this method.
Please let me know if you have anymore questions, thanks!
Message 11 of 19
(1,744 Views)
Hello Meghan,
    Thanks for ur response. I see that u have hard-coded the number of lines to read from the text file. In my application, i cannot hard-code the number of lines to read from text file because this will vary from file to file! Is there any function available in LabVIEW PDA to get the number of lines in a text file? If yes, then the approach u have suggested will work for me.
    Also, please note that the example i had posted did work on the desktop. So i feel that there is indeed a problem with 'Read lines' option checked on PDA.
Thanks & Regards,
Subhashini
Message 12 of 19
(1,736 Views)
Hi Subhashini,
The attached screenshot of a block diagram shows how you can programmatically count the number of lines in a text file.  You can then wire this value into your the N terminal of your For Loop.
Message 13 of 19
(1,706 Views)
Hello Meghan,
    Thanks. Can u please give me the names of the array functions that u have used to 'Convert to an array and get number of rows'? Iam not able to fully make out which array functions u have used. If possible, please send the VI.
Thanks & Regards,
Subhashini
Message 14 of 19
(1,684 Views)
Hi Subhashini,
Attached is the VI which will programmatically determine the number of lines in a text file.  Hope this helps, thanks!
Message 15 of 19
(1,670 Views)
Hello Meghan,
    Thanks. The VI didn't work for me on desktop itself i.e. the "# of lines" is always zero. The only change that i did is that i removed the input to 'Read from Text file' so that it prompts me to select a file.
Thanks & Regards,
Subhashini
Message 16 of 19
(1,664 Views)
Hi Subhashini,
Could you try running the VI with the input wired so that you are not prompted to select a file?  This might be the problem.  If you are still seeing errors, you might want to take a look at this KnowledgeBase.  Give this path format a try, and let me know if it works.
Message 17 of 19
(1,636 Views)
Hello Meghan,
    I ran the VI on desktop with the input wired as u suggested, but still same problem - "# of Lines" is zero.
Thanks & Regards,
Subhashini
Message 18 of 19
(1,603 Views)
Hi Subhashini,
If you transfer the text file attached below to your PDA, and read the # of lines with the VI I sent you earlier, do you still read zero?  If you try running this same VI on your PC rather than the PDA, do you still read zero?
Message 19 of 19
(1,564 Views)
