Does and event structure that never times out consume CPU cycles?
A simple question:  If I have an event structure with -1 wired to the timeout terminal, will it consume CPU cycles if no events are being generated?
(2,620 Views)
No, it should not.
If you are still unsure, just delete the time out event case.....
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,601 Views)
Doh!
Thanks!  Makes perfect sense now...
(2,588 Views)
