Does anybody have Audio Precision LabVIEW 7.0 or 7.1 driver for AP2700?
 Hi
Can someone help me!!  I have this Audio Precision LabVIEW 8.2 driver for AP2700 but I dont have LV8.2 I have LV7.1.  Does anybody have a 7.0 version of the same program.  AP2700 driver is in NI website but they dont give the older version of it.  PLEASE HELP!!!!!!!!!!!!!
(3,861 Views)
Hello lizkingx,
I afraid there are no AP2700 drivers for LabVIEW 7.1. The driver exists for LabVIEW 8.2 because it uses the functionality of of this version. The drivers will not work on any version below LabVIEW 8.2.
You have two options you can request for a driver or you can make your own.
To request a driver click on this request a driver.
You could make your own driver using this make a labview driver.
Christian A
(3,831 Views)
I didn't verify all the VIs aren't broken.  I am sure you will run across some which will require some modifications, but here is a 7.1 version of the driver.  Put in your instr.lib folder
(3,823 Views)
Thank you.  I will the files provided.
(3,759 Views)
