Does anybody have an implentation of the RLS algorithm for adaptive filters?? Please??
I'm trying to design an adaptive filter using the RLS algorithm. I don't want to spend ages doing one if there's one already available. Any help would be fantastic
Message 1 of 11
(5,422 Views)
I have not been able to find any on NI's website. They don't have any example programs for this or KnowledgeBases discussing it. Hopefully someone else out there has one for you!
J.R. Allen
Message 2 of 11
(5,421 Views)
Here
[broken link removed; example no longer available]
Tom Moir
Massey University
New Zealand
Message 3 of 11
(5,314 Views)
the link you posted is not available any more, can you please repost it , i am an great need of it.
thankyou!
Message 4 of 11
(4,701 Views)
Can you see this link [link removed; help topic no longer available]?  This topic is way outside my "experience base", and I don't have these toolkits installed, but hope this helps.
BS
Message 5 of 11
(4,681 Views)
And here is a post that begins "I have successfully implemented the RLS Algorithm in LabVIEW".  Don't know if he's talking about Adaptive Filters, though ...
BS
Message 6 of 11
(4,673 Views)
what do you mean?
Message 7 of 11
(4,670 Views)
if you look closely i posted this question aswell, that you have refferred to. it is true that i have implemented the algo.
the only thinng is that i am having trouble with the input. as you can see in the link!
Message 8 of 11
(4,669 Views)
Maybe you could re-phrase your question. Is the problem when you add noise to the output or something to do with the input? What exactly?
Message 9 of 11
(4,655 Views)
the question is simple. is just want to know how to generate  d(n) i-e desired signal for RLS algorithm. the desired signal is the input to the system which is siganl plus channel noise (we say it is Gaussian), so signal + gaussian . the Problem that i face is that the tap weights never change no matter what i do to the input signal. they only change when i change the low cut off the FIR filter.
Message 10 of 11
(4,650 Views)
