Does anybody have sample programs of labview with a USB 6009 attached to a HC-SR04 sensor?
Hi guys, As it says in the title, I'm looking to run a sample labview program with a USB 6009 attached to a HC-SR04 sensor. Do you guys happen to know where I can find such sample programs, or better yet do you have a sample program yourself?
(3,796 Views)
there is daq assistant in daqmx toolkit why you do not use that ?
(3,785 Views)
Accepted by topic author abcxyz123
Hi abc,
it's a bad combination to use an USB6009 with a SR04 sensor! Did you read the manuals for both devices?
The sensor outputs a pulse of 150µs to 38ms and you need to measure the pulse duration.
On the USB6009 you need to employ an AI to do this and you get a max sample rate of 48kHz giving you a sample resolution of ~21µs. This will result in limited accuracy of your measurement.
The next problem is to output the 10µs TTL pulse needed to trigger a measurement of the SR04: the USB6009 can only drive the outputs with software timing. You will never be able to output pulses with just 10µs duration with the USB6009 alone. Using some additional electronics (using a 555 or similar) on a PCB or breadboard may help here…
@Hatef: how should the DAQAssistent be helpful for this very task?
(3,771 Views)
Grew
thank you for your information about a sensor it was really helpful esp for me
I just want to help to work with 6009
and honestly I did not have any information about this sensor
(3,748 Views)
@Hatef.fouladi wrote:
Grew
If you did not have any clue about this sensor product, why you post then? It is not a help, but just creating noise in the forum.
By the way, I would never advise to use Express VIs for DAQ, you get more trouble with it than benefit (repeated Init/close resources, dynamic data type). You can test the HW from MAX, and after create a proper DAQmx task using DAQmx functions. Of course, you can start with a DAQ Assistant, and convert it into DAQmx functions...
(3,729 Views)
Blokk
I did not have information about sensor but it is not means that i did not have information about the 6009
I am the only person who sell 6009 in my country
by the way I use max to show customer the card is work
also I think Express is simple example but for any kind of that device mode
so newbi can use it make some setting then open front and open front panel of Express to see simple example related to his work
also you always give me Helpful advice
I Hope I could Compensate one day
(3,711 Views)
